I need a recommendation on shocks, and someone who can do a complete inspection on the front end.
If you make down to Houston
I recommend Heitman, on McCarty st
Thank you, but I was looking for someone closer to Atlanta.
(08-23-2016 )74bassman Wrote: [ -> ]Thank you, but I was looking for someone closer to Atlanta.
Mr Hagg. Hes the man!!! 15 mins from Rawze's place.
I have met him, but I tought he just did engine work.
Anyone have a recommendation on shocks for the steers?
(08-23-2016 )74bassman Wrote: [ -> ]I have met him, but I tought he just did engine work.
I pit Monroes on mine. Mr Hagg can fix anything but a broken heart!!
I think I'd go with a gas charged shock. My understanding is it takes a oil filled one several bounces to build up pressure to stop the bounce whereas a gas shock stops it first time.
Where did you get the monroe shocs?? Do you have a part number??
(08-23-2016 )74bassman Wrote: [ -> ]Where did you get the monroe shocs?? Do you have a part number??
I got mine at NAPA. I don't have the part number, but some of the other guys will hopefully chime in.
