Hi
I HAVE A 2013 ISX 15,
I NEED TO SETP UP MY SEMI TRUCK GOVENER SPEED . CAN ANY ONE HELP WITH THAT?
I WANT TO SPEED LOCK MY TRUCK. ANY VIDEO ?
I HAVE A INSITE 6
look in features and parameters on Insite. Simply set it to what u want and send changes.
Under features and parms
Max road speed
Cruse speed
Max RPM without road speed set to 12-1400 = this keeps people from unplugging the speed sensor to disable the speed limit
(12-21-2021 )RollinCoal Wrote: [ -> ]...
Doesn't this also put you in a limited rpm state if the speedo circuit would fault out? I put mine at 1850 so I can drive it normally without the speed sensor for that very reason
