(02-18-2022 )Redland1 Wrote: [ -> ]Let me break down what I did because you got me scared now lol.First thing was to drain the oil out of it from the lower steering box hose.Then I disconnected the steering column lower yoke from the steering gear input shaft.The bearing cap cover came off next along with the washer that was right behind it and a flat bearing that I believe is the thrust bearing.Removed all the old seals and o ring from the cover and reinstalled the new ones.Put everything back together and filled up the reservoir.Next I jacked up the front end,started up the engine,and turned the steering wheel all the way to the left and right for about 10 minutes.Is there anything that I missed or that I should recheck because I definitely don’t want it locking up on me?
The critical part that I described in the earlier post is about dissasembling/re-assembling the main ball-screw / main cylinder that runs thru the middle of it. Your description does not imply that you took it apart that far.
(02-19-2022 )Rawze Wrote: [ -> ] (02-18-2022 )Redland1 Wrote: [ -> ]Let me break down what I did because you got me scared now lol.First thing was to drain the oil out of it from the lower steering box hose.Then I disconnected the steering column lower yoke from the steering gear input shaft.The bearing cap cover came off next along with the washer that was right behind it and a flat bearing that I believe is the thrust bearing.Removed all the old seals and o ring from the cover and reinstalled the new ones.Put everything back together and filled up the reservoir.Next I jacked up the front end,started up the engine,and turned the steering wheel all the way to the left and right for about 10 minutes.Is there anything that I missed or that I should recheck because I definitely don’t want it locking up on me?
Okay,that’s what I was thinking but wanted to make sure.Thanks.
