So the guy that installed my king pins over torqued the grease caps and they blew out when I greased the pins.Is there a way to re-thread both sides?
Pipe fitting die? Home Depot, Rigid.
(01-05-2023 )Waterloo Wrote: [ -> ]Pipe fitting die? Home Depot, Rigid.
It’s not only the caps that have the threads messes up but the wheel spindle assembly ones as well.
(01-05-2023 )Redland1 Wrote: [ -> ] (01-05-2023 )Waterloo Wrote: [ -> ]Pipe fitting die? Home Depot, Rigid.
just some thoughts... the beer is talkin' ...
Speed-gun happy work has no excuse out here.. this most especiually with critical components like king pins and other steering-related parts. Someone gonna get killed like that some day.
Take it back to them and ask them to have the mechanic that did the work tell you what the torque spec was... and watch them clammer around like a worm because they never bother to torque them normally, .. then make them replace the units, requesting they take it out of the technicians pay.
If they refuse, then tell them they will be hearing from your lawyer for the amount they owe you after you pay someone else to fix it properly + the freight you lost that week as a result.
Check for RTV too while you are at it... ;-)
(01-05-2023 )Rawze Wrote: [ -> ] (01-05-2023 )Redland1 Wrote: [ -> ] (01-05-2023 )Waterloo Wrote: [ -> ]Pipe fitting die? Home Depot, Rigid.
Last I heard he went back to Mexico.I walked in on the guy as he was finishing up installing the second cap with an impact and asked him why the hell he used it on something like that and he told me “It will be fine I do it like that all the time”.
If a grease gun is all it took to pop them off then I would say the threads must be pretty much gone. I'm afraid your gonna need new spindles or at the very least take yours off and have new threads cut into them and custom caps made.
Can a machine shop cut new threads into them?
