09-21-2016,
(09-21-2016 )1mattrichert Wrote: [ -> ]hey brock so ur saying if my bags are weathered on bottom even if i cant hear them leaking there still losing air
If you spray soapy water around the bell at the bottom of the bags you should be able to see small bubbles if they're leaking. Because it's such a big surface area it may be harder to spot.
If they're cracking it's time to change them. Check the cab/sleeper bags too, think the go faster from sun rot.
Other things to check, air toggles on the dash, air seat lines.
I had a line on the drivers seat wear thru the other day. Bled of the #2 tank in about a 1/2 hour while parked. The truck is a 2015 FL. Gotta love the attention to little details on new trucks!
