I did the delete on my truck, it ran fine for 2 days with no problems, then I woke up, I turned on the truck and at idle it accelerated on its own and you could hear the sound of the turbo, when trying to accelerate the truck it seemed to choke and suddenly it worked normally for 1 second and then it was back to the same thing! Is a Cummins X15 cm2350A
I just sent you my contact info. I’ll check it for ya or you can send your file to Rawze for a review. It sounds like you’ve missed some things in your tune and it’s jumping modes.
Thanks ! I have to leen how to do it ! But I will send it
(11-18-2023 )AVMB Wrote: [ -> ]Thanks ! I have to leen how to do it ! But I will send it
If you want to learn more about the programming side of things for yourself, or want me to go over a program in detail, explain things, etc... then my mumble voice-chat server is used for that. We discuss engine programming in any detail someone wants to dig into over there...
ref:
http://rawze.com/forums/showthread.php?t...63#pid2163
(11-18-2023 )Rawze Wrote: [ -> ] (11-18-2023 )AVMB Wrote: [ -> ]Thanks ! I have to leen how to do it ! But I will send it
ref: http://rawze.com/forums/showthread.php?t...63#pid2163
And you get to talk plenty of shi#t while you’re at it. It’s a nice passtime
Thanks Mr Rawze will do it !
