10-29-2024,
Hello Rawze,
I have a MIL on my truck (2023 Peterbilt Cummins ISX) The fault code is 1141 (Injector Solenoid Driver Cylinder 2 - Mechanical System Not responding or out of adjustment). I read previous threads on this fault code, however other threads don't have the same symptoms. Truck drives fine, power delivery is normal, no misfire, fuel economy is normal. When I go to start the truck after it being off for 5 minutes or so, I have to crank it for more than 10 seconds or what i do is when it doesn't turn over after 3 cranks, I go back to the off position and then crank it back over after and it starts up within 2-3 cranks. There are no fuel leaks that i could see from the outside. I had the code reset when I was in MN and drove down to Sparks, NV where the light came back on, I had the code scanned and it was the same code. Any help/data/procedures would greatly be appreciated.
Thanks,
Aris
Thanks,
Aris
