| 2010 KW possible bad cecu - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2010 KW possible bad cecu (/showthread.php?tid=10176) Pages: 1 2 |
RE: 2010 KW possible bad cecu - Bigmack713 - 06-23-2025 (06-23-2025 )trucklogger2 Wrote: Cecu will be under cupholderI cleaned those two connectors with a small set of files that I had. There was a little bit of corrosion but not much.Can you send me the part number of the module you changed? RE: 2010 KW possible bad cecu - Bigmack713 - 06-29-2025 (06-23-2025 )trucklogger2 Wrote: To add to that now that I remember more there was a $2 relay burnt on the control board in the cecu which you can check. I took it to a retired electrical engineer who found it.Thank you for pm'ing me so promptly. With the part number you gave me (p21-1019-303)I looked up the parts diagram. And yes this little box controls everything that is wrong with my truck currently. I'm in the process of checking for corrosion and or broken wires. I don't want to jump to conclusions but this might be the issue. I've isolated it by unplugging multifunction switch headlight harnesses and rocker switches yet the single turn signal light stays on on the back of the truck. RE: 2010 KW possible bad cecu - Bigmack713 - 06-29-2025 (06-29-2025 )Bigmack713 Wrote:I open up the module and it was full of corrosion and some rust. Some of the components were corroded or missing. Obvious signs of water damage.(06-23-2025 )trucklogger2 Wrote: To add to that now that I remember more there was a $2 relay burnt on the control board in the cecu which you can check. I took it to a retired electrical engineer who found it.Thank you for pm'ing me so promptly. With the part number you gave me (p21-1019-303)I looked up the parts diagram. And yes this little box controls everything that is wrong with my truck currently. I'm in the process of checking for corrosion and or broken wires. I don't want to jump to conclusions but this might be the issue. I've isolated it by unplugging multifunction switch headlight harnesses and rocker switches yet the single turn signal light stays on on the back of the truck. RE: 2010 KW possible bad cecu - Bigmack713 - 06-30-2025 Just wanted to update everyone.i changed the above mentioned module and all is working as it should RE: 2010 KW possible bad cecu - Rawze - 07-01-2025 (06-30-2025 )Bigmack713 Wrote: Just wanted to update everyone.i changed the above mentioned module and all is working as it should Thanks for the update. I am sure it will help someone in the future. Now the next thing to pursue is how to prevent it from occurring again. |
