| Oil pressure & weather conditions - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Oil pressure & weather conditions (/showthread.php?tid=10178) Pages: 1 2 |
RE: Oil pressure & weather conditions - 3406E - 06-25-2025 (06-25-2025 )Rawze Wrote: first and foremost ... bad deletes can make the oil run hotter than it should, and therefore cause lower than normal oil pressures as a result. It’s not deleted of any sort still running egr, planned on getting it deleted when Rebuilding RE: Oil pressure & weather conditions - mikkhh - 06-25-2025 When was the last time the EGR cooler was cleaned? Intake EGR mixer pipe cleaned? IMAP and back pressure sensor replaced? In my area Rotella T6 full synthetic costs 10x more than good brand 15w40 mineral or 10w40 semo synthetic. RE: Oil pressure & weather conditions - 3406E - 06-25-2025 All This time i thought full syn was better,I’m going start to use the t4 15-40 RE: Oil pressure & weather conditions - marek4792 - 06-25-2025 Assuming your tune isn't the issue like Rawze says or an underlying performance/ cooling issue, your oil pump could have a weak/ broken regulating spring. I ran into that one on mine. Went from mid to high 30's down into the low 30's one day. Swapped when doing rods and mains and it returned to high 30's. Of course each engine is different. Most important if the proper gear lash can't be obtained, get another one until it does. RE: Oil pressure & weather conditions - mikkhh - 06-25-2025 (06-25-2025 )mikkhh Wrote: Why you waste money on synthetic oil? Well I made little mistake with that viscosity assumption, in my area they sell 5w40 Rotella T6, BUT it can be either 10w30 or 15w40 or 5w40 or 0w40... RE: Oil pressure & weather conditions - 3406E - 06-25-2025 In my area 15w 40 t4 is like 85 bucks and the t6 15-40 is 126 I think. 5gals RE: Oil pressure & weather conditions - 3406E - 06-25-2025 So just to clear up my confusion you guys are saying the T4 15w 40 is thicker than the 15w 40 t6? I thought full syn would be thicker. Or do i have it backwards |
