| Front structure seal - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Front structure seal (/showthread.php?tid=10487) Pages: 1 2 |
RE: Front structure seal - Rawze - 01-26-2026 (01-25-2026 )3406E Wrote: Thin layer of permatex red jelly. I do not encourage people to use a sealant that hardens .. because I have seen too many times, the passage way for the oil back to the regulator (across the mack side of the engine cover) get a flake in it, and causing some serious harm. - Someone needs to well keep that in mind if they do use a sealant that hardens. personally, I just make sure the cover and all mating surfaces are very flat ans clean.. and then maybe use a light dusting of anti-sieze on the gasket so that it seats well, rubber stays malliable, etc. |
