Truck software advice - Printable Version
+--- Thread: Truck software advice (/showthread.php?tid=1345)
Pages: 1 2
RE: Truck software advice - Rawze - 01-22-2017
(01-22-2017 )earnies2 Wrote:
(01-11-2017 )Rawze Wrote:  This looks to me like nothing but a chineese fake Nexiq that has been re-packaged. Most people report a LOT of problems with them. They tend to work for a short while, then go bad.
There are so many fakes running around, i would suggest your local fleetpride to get a genuine Nexiq. That way if you have trouble with it, you can take it back to them for an exchange if necessary.
What is the cost at Fleetpride and what about the software?
I think I paid $900 or so for mine.
RE: Truck software advice - fargonaz - 01-22-2017
Having problems already?
RE: Truck software advice - superbug - 03-01-2018
Is the Nexiq also good for a 2005 model ISX. I'm looking to buy a 2005 Volvo on the 11th and would like to take some type of code reader to check the codes on it.
RE: Truck software advice - Chamberpains - 03-02-2018
Ya, nexiq is a compatible adapter. The link on the original post deadends for me so I can't see what exact nexiq adapter they were linking to. But most of the nexiq's sold are cheap chinese knock offs. They are built really cheap and can break apart pretty easily. That being said, I have one and it's worked for a year now and done everything I need to do with it. It's basically you get what you pay for on the cheap knock offs.
RE: Truck software advice - Rawze - 03-02-2018
Hardware-wise, all that someone needs to copy the program in/out of their ecm themselves is a laptop (windows xp, windows 10, or windows 11) + an adapter (called a data-link adapter) that goes between this laptop and the engine/vehicle.
The adapter ...
== If someone only has vehicle with cummins engines, or if they want a cheap solution, then a Chineese 'Inline-5' or 'Inline-6' adapter off of ebay or amazon works just fine. They have no issues generally and are far cheaper than anything else, only about $300 bucks or so. The red engine maker themselves also sells official 'Inline' brand adapters, but they are for more moneys ... and work just as well too.
== The alternative to this is a 'Nexiq' brand adapter. They are more suited for someone who owns Detroit, CAT, Volvo, etc.. and not just a cummins. The only trouble with them however is that ...
- A, they are more expensive by quite a little bit ...
- and B, The Chineesuim Nexiq-brand fakes that are sold all over the interwebs tend to fail and go bad,.. or not work properly.
This means that if someone buys a 'Nexiq' adapter.. they need to go to a local FLeet pride store or other official place that sells them and buy one that way vs. off the webs. They are also a lot more expensive at $800+ .. so it just is not really worth it for the guy who only has one truck or 2 trucks, and they all heave a red red engine.
Myself,... as someone that helps others..
I have Several cheap Chineese 'Inline' adapters, and also I have 2 'Nexiq' adapters here. -- Turns out the first Nexiq that I purchased off the webs was a fake that worked for about 6 months then got bricked because the official Nexiq adapter drivers, after an update, attacked and destroyed it. Nexiq (and Amazon) apologized to me and when I gave them the serial number of the adapter, and they said there were thousands of units with that same serial number that had been cloned from china accidentally sold as official ones.
I was sent a new one for my troubles for free, since I had gone through Amazon, and it was supposed to be legitimate. The 2nd one i purchased, I got from a local fleet-pride store and it was genuine. It still works great to this day, and is the one I use when not using my inline adapter.
However ... It is so rare for me to use a Nexiq, that it usually just collects dust and I have never really needed it much.
That is my own experience with them, I have seen a lot of guys buy Chinese Nexiq adapters in the past who loved them for a while, but only regretted it later when they bricked. I have not heard any stories of Chineese Inline adapters doing this.
-- The adapter itself (inline, nexiq, whatever) is the most important part actually. - As far as software goes ... for the red engines ... well ... It, along with some ehemm "fixes" to make it all work, are all over the internet like paint on the wall (for free), if a person simply looks for in the right places for it. - I am not encouraging this, but just stating the obvious. Software trading is not allowed on this forum, but that does not stop people from getting what they need elsewhere.
(Summary)...
I usually tell people that if they have a red engine and do not plan on working on Detroits etc. to simply just get an Inline adapter. I can't remember the last time I even fired up my Nexiq. If they do get a Nexiq, then don't try to get the cheapest one. Go to a fleet-pride or other official store to get an official one, so that you do not regret it later. When it comes to Inline adapters however, an official one, or a china knock-off, they all seem to work just fine without issues.
Tags:
inline vs nexiq, nexiq vs inline, inline adapter, nexiq adapter, cummins adapter, flashing ecm
RE: Truck software advice - alborz - 03-02-2018
Thank Rawze. Can you list what are needed to get fault codes out of cummins engine?
If you attach the picture of the that be the best.
RE: Truck software advice - Wiseman - 03-02-2018
Alborz ,
For centuries the rule remains the same ! And the rule is :
Puff puff pass
Is not fair to smoke alone!
