| Poly bushings - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Poly bushings (/showthread.php?tid=2384) Pages: 1 2 |
RE: Poly bushings - Hammerhead - 11-17-2017 (11-17-2017 )Waterloo Wrote:(11-15-2017 )ZeroNthedark Wrote: This doesn't address original question from dhirocz, but as far as rear bars, this is what I went with. I'm 99% sure iirc that mine are Euclid brand Waterloo, so almost any truck parts Place will be able to get them for you. RE: Poly bushings - ZeroNthedark - 11-17-2017 What he said ^^ If you have any sort of shop nearby that does brakes, suspensions, etc., for big trucks, they should be able to get everything you need. Mine came labeled as "Uni-Rod" in a plain white box. It'll be helpful if you have part numbers for stock rods so they make sure you get correct ends. Just cut to length and do plug welds first, then around the ends. The link above is the instruction sheet that came with mine. |
