| PARTS STORE - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: PARTS STORE (/showthread.php?tid=3013) Pages: 1 2 |
RE: PARTS STORE - Rawze - 04-21-2018 (04-21-2018 )lonestar16 Wrote: is it possible to make the system work like it is suppose to as long as u keep it clean as best as u can..i no idling is a big part in making the system fail sooner then it should ..not good with computer so can anyone recommend a good shop to have the insite ran so i can get some base numbers to keep and eye on.. You can keep the system working if you keep after it well enough. I would recommend getting your own Insite software though and doing everything yourself or it is going to break you. RE: PARTS STORE - lonestar16 - 04-21-2018 thank u sir didnt know i had to be a computer guy to just be able to keep the truck up and running .any recommendation on what insite sofeware i should go far and is it hard to work the software..thank yall have all been a big help in learon how to do it the right way. RE: PARTS STORE - Hammerhead - 04-22-2018 (04-21-2018 )lonestar16 Wrote: thank u sir didnt know i had to be a computer guy to just be able to keep the truck up and running .any recommendation on what insite sofeware i should go far and is it hard to work the software..thank yall have all been a big help in learon how to do it the right way. Go to eBay and search out an Inline 5 (or 6) with Insite 7.6.X Should be a lil under US$400.00 Insite isn't terribly complicated. You want to find an older laptop with Windows 7 is best. Remember, this laptop is a tool, not a toy! So no internet surfing on it. It is to connect to, and work on your truck only! RE: PARTS STORE - Chamberpains - 04-22-2018 Windows 7, 32 bit. The 64 bit can be a little disagreeable with software of that time. |
