| ISX 435 OIL PSI LOSS - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX 435 OIL PSI LOSS (/showthread.php?tid=3610) Pages: 1 2 |
RE: ISX 435 OIL PSI LOSS - Joelbe - 10-10-2018 Stay safe Rawze.. praying for you guys in path of hurricane!! RE: ISX 435 OIL PSI LOSS - Joelbe - 10-12-2018 Hi Rawze.. Did you survive the storm? Everyone ok? I started EGR tune up. I MAP sensor clogged dont know how it even worked..Tomorrow we remove all components and clean. new I map and differential psi sensor! Thanks for all your help! May try your over head set also! Need to get torque wrench you have mentioned the gauge style! RE: ISX 435 OIL PSI LOSS - Rawze - 10-12-2018 (10-12-2018 )Joelbe Wrote: Hi Rawze.. Did you survive the storm? Everyone ok? I started EGR tune up. I MAP sensor clogged dont know how it even worked..Tomorrow we remove all components and clean. new I map and differential psi sensor! Thanks for all your help! May try your over head set also! Need to get torque wrench you have mentioned the gauge style! all good here, thanks for asking. RE: ISX 435 OIL PSI LOSS - Joelbe - 10-12-2018 Rawze, have you ever tried seafoam in a motor? Could this actually clean out a soot filled motor ? Your thoughts? RE: ISX 435 OIL PSI LOSS - Rawze - 10-13-2018 (10-12-2018 )Joelbe Wrote: Rawze, have you ever tried seafoam in a motor? Could this actually clean out a soot filled motor ? Your thoughts? http://rawze.com/forums/showthread.php?tid=3103&pid=26866#pid26866 and... http://rawze.com/forums/showthread.php?tid=1876&pid=16597#pid16597 and... http://rawze.com/forums/showthread.php?tid=1273&pid=10573#pid10573 Simply fix the engine problems that are making it have excess soot, change the oil at shorter than normal intervals a few times, etc. to get it back right. RE: ISX 435 OIL PSI LOSS - Joelbe - 10-13-2018 Got it! Thumbs down! |
