| Fuel pump cm 2250 update help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: Fuel pump cm 2250 update help (/showthread.php?tid=3867) Pages: 1 2 |
RE: Fuel pump cm 2250 update help - imalumberjack - 12-13-2018 I have a cm 2250 and it came with 4 screw (bolt) head. The cm 2250 I think came with two different pumps the early years were a 6 screw (bolt) and later were 4 screw (bolt) all cm 2350 pumps were 4 screw (bolt). The barrel and plunger on 4 bolt heads between cm 2250 -2350 are different one has a orange o-ring one is grey (no you cannot just change o-ring) |
