Cam/Crank Sensors - Printable Version
+--- Thread: Cam/Crank Sensors (/showthread.php?tid=4016)
Pages: 1 2
RE: Cam/Crank Sensors - Waterloo - 01-18-2019
Oh, when replacing sensors, lube the o ring with either Vasoline or anti-seize. Makes install much easier and less chance of damaging the o rings.
RE: Cam/Crank Sensors - RyanC - 01-18-2019
https://www.matcotools.com/catalog/product/SPG824C/1-4-X-24-SLOTTED-SCREWDRIVER-GREEN/
I have a 30 inch version of this with the tip ground a little sharper.
You walk the tip around the base twisting slightly and try to walk it out evenly. Usually pops right out once you get it to a fully twist of screws driver head.
Take your time don't get frustrated and DO NOT PRY ON IT WITH A PRY BAR....
When you get good at them they only take a few minutes to do. Guess I owe a thanks to the old 444e motor and that high failure part.
RE: Cam/Crank Sensors - Lonestar10 - 01-18-2019
Yeah the 444e is the 7-3 in pickups
