| Diesel particulate trap 1 psi codes - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Diesel particulate trap 1 psi codes (/showthread.php?tid=566) Pages: 1 2 |
RE: Diesel particulate trap 1 psi codes - Rawze - 07-01-2016 It is good that you shared that with everyone. I have been outside all day working on my truck and just got back inside. regen temps look a little high is what i noticed, but high regen temps usually means it is doing its job. RE: Diesel particulate trap 1 psi codes - jorden486 - 07-15-2016 So cleaned or new injector solved the problem? RE: Diesel particulate trap 1 psi codes - joed2323 - 07-16-2016 Yes the def injector was plugged up. Its a daily struggle out here in the oil fields. Our trucks take a beating idling all the time. bumping the idle up to 11-1200 while loading/offloading oil beats up these aftertreatment systems. I think a good egr maintenance schedule on these trucks to help keep the sensors clean will help in the long run. So we will see how this works. |
