Oil leak behind engine?? Cm2250 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Oil leak behind engine?? Cm2250 (/showthread.php?tid=669) Pages: 1 2 |
RE: Oil leak behind engine?? Cm2250 - jimeneztrans84 - 07-23-2016 I'm going to keep an eye on it.. when it starts getting worse I'll change it out. I just got done rolling new bearings and oil pump on Monday. Now I'm still fighting this fuel pressure rail code 1911, that hopefully I can fix monday and hoping it's not a fuel pump.... RE: Oil leak behind engine?? Cm2250 - morrison8 - 07-24-2016 (07-23-2016 )jimeneztrans84 Wrote: I'm going to keep an eye on it.. when it starts getting worse I'll change it out. I just got done rolling new bearings and oil pump on Monday. Now I'm still fighting this fuel pressure rail code 1911, that hopefully I can fix monday and hoping it's not a fuel pump.... Can I ask where you had the bearings done? RE: Oil leak behind engine?? Cm2250 - jimeneztrans84 - 07-24-2016 Yes this shop in fontana, ca let me know if you need the info? RE: Oil leak behind engine?? Cm2250 - morrison8 - 07-24-2016 (07-24-2016 )jimeneztrans84 Wrote: Yes this shop in fontana, ca let me know if you need the info? OK thanks, I had mine done last month at a shop in Indiana, Dumped out 8 gal of oil getting back to California, Replaced front crank seal and oil pan gasket Oil pan gasket needs silicone on the corners where the block meets the front and rear housings. All good now |
