CM870 loosing coolant/possible inflame - Printable Version
+--- Thread: CM870 loosing coolant/possible inflame (/showthread.php?tid=6775)
Pages: 1 2
RE: CM870 loosing coolant/possible inflame - Squish099 - 11-19-2020
(11-19-2020 )Koren Wrote:  Thanks for the replies. All of the pulleys spins fine. But I can't manually spin the crankshaft.
I tried to set up with Haggai but they are busy till December 7. I'm stopping driving at this time but I'm afraid I have to find a shop first since it probably won't start at all after I leave it for a couple of days.
Any shops you guys can recommend in GA/FL area who does an inframe?
How do I pull out the copy of the software of the ECM?
Just wait for haggai.. Theyre they only shop that is close to you that will build it right!
RE: CM870 loosing coolant/possible inflame - tree98 - 11-19-2020
^^^^^^^ what he said ^^^^^^
You'll regret it otherwise trust me.
RE: CM870 loosing coolant/possible inflame - hhow55 - 11-19-2020
Go to Haggai
RE: CM870 loosing coolant/possible inflame - Volvo8873 - 11-19-2020
x4!!!! ^^^^^
RE: CM870 loosing coolant/possible inflame - amermextrucker - 11-20-2020
Mr. HAGG will take care of you right and you're not that far. I went all the way from Illinois to see him. Well worth it.
