| Dash lights flashing - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Dash lights flashing (/showthread.php?tid=799) Pages: 1 2 |
RE: Dash lights flashing - Rawze - 08-27-2016 At the main fuse panel, there is a row of very small 5A fuses at the far left of the pannel. they are notorious for the contacts getting tarnished, then making intermittent connections. They are also the fuses responsible for the dash display, gauge cluster, cab control, etc. and I had one get flaky on mine last year, causing the cruise to act up sometimes, and other wierd, unexplainable problems like the passenger window not working sometimes, etc. -- NONE of these fuses were bad at all,.. but replacing them ALL with brand new 10A fuses cured a lot of little quirks I would see. I recommend replacing ALL THOSE FUSES AT ONCE every couple years along with any others that have discolored pins as a good start to solving problems like you are describing, and as well, if you have a factory compas and/or clock, unplug them for a couple days and see if problems go away as well. RE: Dash lights flashing - Dcolumbia - 09-13-2016 I got distracted by other issues with the truck, but today I finally remembered to unplug the compass module. My lights haven't flashed since. Thanks Waterloo and Rawze. RE: Dash lights flashing - Waterloo - 09-13-2016 (08-27-2016 )Gena Wrote: Hi everybody, Well, I would think the Diamond Logic software would catch the issue if it is in the canbus system... It popped right up, my compass module being the issue with my ABS. The mechanic scratched his head and said look at this... I bought a new module on eBay for $20 vs the $350 the dealer wanted. Problem solved. RE: Dash lights flashing - Dcolumbia - 09-19-2016 Ok, so yesterday I did the injector leak down test. While I was reinstalling the front metering valve, I dropped one of the t 30 bolts. While doing an extensive search of the frame and block I came across the ground cable that comes off of the rear of the starter and bolts to the block. That cable had rotted thru at the block end. I put a new end on it and plugged the compass module back in thinking that it could be the source of the flashing light problem I was having. That turned out to be the problem. Truck seems a bit more responsive now too. Just thought it might help somebody else out. |
