| Isx head question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Isx head question (/showthread.php?tid=834) Pages: 1 2 |
RE: Isx head question - ahm700 - 09-08-2016 [attachment=1927]Well pulled the head. I didn't see the signs of oil leak I was hoping for so maybe the gear case. The cam bearings was about shot. They was a few things that maybe odd not sure. The cam gears popped off with no problem nothing like I was expecting. Maybe 20 to 30 pounds on bolts of puller. Also head practically separated itself from the block. Here is a pic or 2 of progress. The bracket I used was from a auto parts store I spent between 30 and 50 for bracket RE: Isx head question - ahm700 - 09-08-2016 (09-08-2016 )ahm700 Wrote: Well pulled the head. I didn't see the signs of oil leak I was hoping for so maybe the gear case. The cam bearings was about shot. They was a few things that maybe odd not sure. The cam gears popped off with no problem nothing like I was expecting. Maybe 20 to 30 pounds on bolts of puller. Also head practically separated itself from the block. Here is a pic or 2 of progress. The bracket I used was from a auto parts store I spent between 30 and 50 for bracket RE: Isx head question - ahm700 - 10-10-2016 Ok got truck back together. I replaced head,both fuel pumps,damper,front and rear motor mounts,cab bushings,low and high fuel pressure regulators,fan clutch,rear main seal,Bell housing gasket and clutch. Around a year ago had a shop replace clutch and rebuild transmission. They put the wrong clutch in it the springs on the clutch disc was hitting fly wheel bolts. I have been running for about a week or around 2500 miles and seem to be in the 7 mpg range. I am running the 650 tune and will be going back to the 485 tune in a few days when I get settled into the run I going to be on. So fuel mileage should go up from there. The vibration I have been chasing is probably 90% gone. RE: Isx head question - jorden486 - 10-13-2016 Curious if there is a fuel gain or decrease from the tune change. Keep us posted RE: Isx head question - Hammerhead - 10-13-2016 (10-10-2016 )ahm700 Wrote: Ok got truck back together. I replaced head,both fuel pumps,damper,front and rear motor mounts,cab bushings,low and high fuel pressure regulators,fan clutch,rear main seal,Bell housing gasket and clutch. Around a year ago had a shop replace clutch and rebuild transmission. They put the wrong clutch in it the springs on the clutch disc was hitting fly wheel bolts. I have been running for about a week or around 2500 miles and seem to be in the 7 mpg range. I am running the 650 tune and will be going back to the 485 tune in a few days when I get settled into the run I going to be on. So fuel mileage should go up from there. The vibration I have been chasing is probably 90% gone.ahm700, did you do this work yourself? I think you're referring to the Flywheel Housing/Rear Structure, if you are and you did, how was it to do, and any tips? I've done the flywheel housing on a S60, but not an ISX...yet. RE: Isx head question - ahm700 - 10-13-2016 (10-13-2016 )Hammerhead Wrote:(10-10-2016 )ahm700 Wrote: Ok got truck back together. I replaced head,both fuel pumps,damper,front and rear motor mounts,cab bushings,low and high fuel pressure regulators,fan clutch,rear main seal,Bell housing gasket and clutch. Around a year ago had a shop replace clutch and rebuild transmission. They put the wrong clutch in it the springs on the clutch disc was hitting fly wheel bolts. I have been running for about a week or around 2500 miles and seem to be in the 7 mpg range. I am running the 650 tune and will be going back to the 485 tune in a few days when I get settled into the run I going to be on. So fuel mileage should go up from there. The vibration I have been chasing is probably 90% gone.ahm700, did you do this work yourself? It's not that bad just be sure to get a good transmission Jack and also need to support engine. |
