| Cm870 demandated hot egts - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm870 demandated hot egts (/showthread.php?tid=8380) Pages: 1 2 |
RE: Cm870 demandated hot egts - Upnorth83 - 11-11-2024 I love this site. I read threads for fun on here. I know my problems are not original. I just feel like I pissed you off and I apologize. RE: Cm870 demandated hot egts - Upnorth83 - 11-11-2024 The 40 41 pounds of boost is abnormal that’s why I mentioned it as well. Usually 38 is normal pulling hard at around 1350 1400 rpm, much higher rpm and boost falls off a lil bit. I pull 105500 through the mountains daily. RE: Cm870 demandated hot egts - Rawze - 11-11-2024 (11-11-2024 )Upnorth83 Wrote: This is what I was referring to with the cold weather https://rawze.com/forums/showthread.php?tid=2915&pid=24825#pid24825 - That is a known issue for -20c(extreme cold) temps and below only. /,.. so your assumption on that thread is a bit mis-guided. - ALSO.. any decent de-mandate would have addressed that issue as well. =================================== Your boost issue (high EGT's and high oil temps) is IS MOST LIKELY bad programming ./.. its THIS>>> Rawze Wrote:What you are describing is the most common derate that CM870 engines get. It is very well known.ref: http://rawze.com/forums/showthread.php?tid=8370&pid=72522#pid72522 Your HIGH OIL TEMPS is this... ref: http://rawze.com/forums/showthread.php?tid=9108&pid=78036#pid78036 BAD PROGRAMMING!!!. AND YOU PUTTING ON AN AFTER-GARBAGE COOLER mods on it HIDES THE HIGH OIL TEMPS ISSUE, SO NOW YOU CANNOT TELL, AND WILL NOT KNOW WHEN THE ISSUES GETS FIXED PROPERLY!!!. RE: Cm870 demandated hot egts - Upnorth83 - 12-26-2024 I want to give an update on this. Rawze was correct as usual. I had a horrible tune. They had timing way advanced and they had tons of faults blocked!! None of the ROM derates were done either. Bengy has been helping me figure it out like a champ. Once the crap was removed I found that I also had other problems. I kept getting faults for low voltage to vgt controller and fan actuator. I replaced oem harness to ecm because that’s where the fan circuit was ran and after doing diagnostics tree in insite I got some strange results. I also replaced fan actuator. After this it was suggested to splice power and ground in to the engine harness in the vgt circuit. After doing all this codes still kept coming back but only when the rpm’s hit 1800 rpm’s out the engine was cold. Also I kept getting voltage high or shorted to high source to Jake solenoids. The Jake fault would hit hundreds of times just glad on and off. I took the entire engine harness apart looking for rubs and shorts and found nothing. Finally I borrowed a test ecm and installed it. I went for a test drive and could not get one fault to hit, where as before I could trip the faults like a light switch I knew exactly hope to set them off. I have since installed a new reman ecm from cummins and am waiting for a flash will update after. Also want to thank Rawze and Bengy88 for all your help and smarts. This whole experience has sparked an interest of learning more about these engine systems and programming. You guys are amazing!!! Thank you. RE: Cm870 demandated hot egts - Mr Hagg - 12-26-2024 I also see that alot of these 870's will have the cam timing wrong aswell. Some of them ran a 6/6 timing and some 4/6... And when someone flashes a file set up for the 4/6 in a 6/6 truck it will cause temps to be higher and smoke more... RE: Cm870 demandated hot egts - Upnorth83 - 12-26-2024 Yeah my cam timing is set at 4 6 when I rebuilt it and put new cams in it. RE: Cm870 demandated hot egts - Upnorth83 - 12-26-2024 Yeah mine I set to 4 and 6 when I rebuilt it and put new cams in it. RE: Cm870 demandated hot egts - Rawze - 12-27-2024 (12-26-2024 )Upnorth83 Wrote: Yeah mine I set to 4 and 6 when I rebuilt it and put new cams in it. For the CM870's, it goes by your engine CPL. The program in the ecm must match the profile as well. .. here is an old post with the official CPL vs. Wedge numbers... ref: http://rawze.com/forums/showthread.php?tid=3464&pid=29926#pid29926 |
