| Cat c15 BXS IVA issues - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: Cat c15 BXS IVA issues (/showthread.php?tid=9249) Pages: 1 2 |
RE: Cat c15 BXS IVA issues - trucklogger2 - 12-02-2023 Mommaburt would know more I think or check out Adept Ape on u-tube may have a video on this. It' s been quite a few years since I drove one but seems to me you can hear a difference when driving them if one of the iva heads is cracked- maybe blue smoke also? Check for oil contamination on head thru plugs harness. This will cause bad communication https://www.youtube.com/watch?v=oBo7vLA3uF4&t=604s added video link RE: Cat c15 BXS IVA issues - Nerv - 12-08-2023 Replaced actuator, passed test no more codes. Problem solved. Thanks! RE: Cat c15 BXS IVA issues - Rawze - 12-08-2023 (12-08-2023 )Nerv Wrote: Replaced actuator, passed test no more codes. Problem solved. Now is the task of finding out why it failed to begin with... so that it does not happen again (something causing it) ... or if the rest of them need replacing (simply worn out). RE: Cat c15 BXS IVA issues - PolishHammer - 12-19-2023 (12-08-2023 )Rawze Wrote:(12-08-2023 )Nerv Wrote: Replaced actuator, passed test no more codes. Problem solved. seen this lots on the accert kittys most of the time the fella that was in the top end didnt tie wrap the wiring to the provided loops in the rocker box the wires contact the valvetrain and rub out shorting the coil. i have had the wiring rub out so bad it shorts the ecm and had the jakes not working on medium or high. RE: Cat c15 BXS IVA issues - Nerv - 05-26-2025 Update to this; the pigtails needed to be replaced as well they were worn out/broken, for anybody that has this issue.. cat sells the pigtails for the IVA connecters. |
