Injector Spill Valve - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Injector Spill Valve (/showthread.php?tid=3751) |
RE: Injector Spill Valve - indian_richard - 11-27-2018 (11-27-2018 )Rawze Wrote:(11-27-2018 )rgreen Wrote: If it was my truck truck I will go back and pull all the injectors 1 by 1 and write them on a paper and then go back to insite and correct the missing info. Yeah I just pulled the valve cover and took a look. I can see the number and I'm gonna use my iPhone camera with the flash. There's like 3 sets of numbers. Is the barcode the one set of numbers with letters? RE: Injector Spill Valve - snailexpress - 11-28-2018 (11-27-2018 )indian_richard Wrote:(11-27-2018 )Rawze Wrote:(11-27-2018 )rgreen Wrote: If it was my truck truck I will go back and pull all the injectors 1 by 1 and write them on a paper and then go back to insite and correct the missing info. Should looks like this [attachment=4459] RE: Injector Spill Valve - indian_richard - 11-28-2018 :oh: (11-28-2018 )snailexpress Wrote:(11-27-2018 )indian_richard Wrote:(11-27-2018 )Rawze Wrote:(11-27-2018 )rgreen Wrote: If it was my truck truck I will go back and pull all the injectors 1 by 1 and write them on a paper and then go back to insite and correct the missing info. Thnx Snail, I referred back to your reply in the first page of this post. I updated all the barcodes successfully. Since I was at it, I checked one of my other trucks. It's a salvaged I put back together and had to put a new ecm on. The guy I had tune do the ecm never set the barcodes. It's been running like that for 100,xxx miles. :oh: |
