T660 - Side Light / Blinker - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: T660 - Side Light / Blinker (/showthread.php?tid=4262) |
RE: T660 - Side Light / Blinker - Rawze - 03-17-2019 it is also well known that fuses and breakers in the fuse panel can get discolored pins and cause ghost problems like that. Also, it being a PACCAR cab controller,... they are well known for software glitches and problems, especially regarding the gauge cluster lights and other tings. -- Sometimes the cab controller needs a hard reset to fix these ghosts... search results... http://rawze.com/forums/showthread.php?tid=1258&pid=10452#pid10452 http://rawze.com/forums/showthread.php?tid=255&pid=1628#pid1628 http://rawze.com/forums/showthread.php?tid=2121&pid=18292#pid18292 http://rawze.com/forums/showthread.php?tid=3341&pid=28826#pid28826 RE: T660 - Side Light / Blinker - JKBowman - 03-17-2019 Thanks - I'm on it! |
