| Doing cams and front structure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Doing cams and front structure (/showthread.php?tid=958) |
RE: Doing cams and front structure - Brock - 10-16-2016 (10-16-2016 )Rawze Wrote:(10-15-2016 )Brock Wrote: Well I'll be damned.... I've never seen this before! I didn't think it was possible with the weight I haul and the idle time I have but here it is, a few thousand km and still looks pretty good! I'm guessing it's more or less residuals left that have it that dark, I think my next oil change will clear it out. Give it boost at idle you say? lol damn. That's what I did when my turbo was pushing oil but once I fixed the turbo, I turned my idle boost back down. RE: Doing cams and front structure - Brock - 10-17-2016 Well my trucks being a asshole today. Since shimming my oil pump, I've been running down the road around 50psI at 200 degrees and a couple psi lower when warmer.... .But mid day today it randomly went and dropped 10psi! I'm running down the road at 38psi at 200 degrees now. Bullshit! RE: Doing cams and front structure - RPM1 - 10-17-2016 (10-17-2016 )Brock Wrote: Well my trucks being a asshole today. Since shimming my oil pump, I've been running down the road around 50psI at 200 degrees and a couple psi lower when warmer.... something is amiss i would pull the oil filter and cut it open and Dubble check oil press with a gauge for starters then look for blown seals orings turbo seals RE: Doing cams and front structure - preacherboy24 - 10-17-2016 (10-15-2016 )Brock Wrote: Well I'll be damned.... I've never seen this before! I didn't think it was possible with the weight I haul and the idle time I have but here it is, a few thousand km and still looks pretty good! This is mine after an oil change. I have an 870 and the Speedco guys were amazed. Usually on these engines the oil is black right after startup. Mine is still pretty clean after a couple of thousand miles. RE: Doing cams and front structure - in2trux - 10-17-2016 (10-17-2016 )Brock Wrote: Well my trucks being a asshole today. Since shimming my oil pump, I've been running down the road around 50psI Sat 200 degrees and a couple psi lower when warmer....Sounds like the sending unit is on the way out. Ours would go to 0,20 and back to normal,freaked me out. Been fine ever since I changed it. Still want to add a mechaical gauge. |
