Peterbilt 2015 cm2350 list of issues - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Peterbilt 2015 cm2350 list of issues (/showthread.php?tid=9874) |
RE: Peterbilt 2015 cm2350 list of issues - Trey7981 - 01-15-2025 (01-15-2025 )tree98 Wrote: It's a pump that makes as much as 30k psi. There are numerous places the system could be leaking internally and you'll never know unless you do the leakdown test. It takes about 5 minutes with insite. I meant the head of the fuel pump.. so that insite I bought is how I do the leak down test? I watched Rawls leak down video and been calling around for that tester.. RE: Peterbilt 2015 cm2350 list of issues - tree98 - 01-15-2025 (01-15-2025 )Trey7981 Wrote:(01-15-2025 )tree98 Wrote: It's a pump that makes as much as 30k psi. There are numerous places the system could be leaking internally and you'll never know unless you do the leakdown test. It takes about 5 minutes with insite. Yea insite runs the test. What tester are you trying to find? You might have watched the leakdown test video for the 870/871, those engines use a bubble tester, you don't need that. all you need is insite, Rawze made a video of how to do the test for the common rail engines (cm2250 and newer) here it is..... https://odysee.com/@rawze:d/isx-injector-leak-test-for-the-cm2250:e RE: Peterbilt 2015 cm2350 list of issues - Trey7981 - 01-15-2025 Ok so I watched that video but how do I test each injector? Is that in insite too. RE: Peterbilt 2015 cm2350 list of issues - tree98 - 01-15-2025 For that you'll need the caps. Those you have to buy from cummins, you might not need them though. If it passes there's no need to cap injectors. RE: Peterbilt 2015 cm2350 list of issues - Trey7981 - 01-19-2025 Anyone got any input on {non-oem} reman injectors “ only if you have used them please” RE: Peterbilt 2015 cm2350 list of issues - tree98 - 01-19-2025 You will regret it !!!! No I've never used that particular brand but I can tell you that regardless of brand the ISX doesn't like aftermarket injectors, you've been warned. Here's a heart warming story of someone who did not listen to that advice. https://youtu.be/Ptv-xO0gHNQ?si=e9GSwRuIL4XqafVZ RE: Peterbilt 2015 cm2350 list of issues - Trey7981 - 01-19-2025 FYI, ran leak down and lost about 8600 psi. Ordered test caps. Also ran all the injector test in insite #1and #4 have an issue. I did run two full tanks of injector cleaner from Lucas and a good bit of power has returned and the motor is a lot quieter. RE: Peterbilt 2015 cm2350 list of issues - Trey7981 - 01-23-2025 Verdict is in… #1 injector we cleaned the tube thru the head and it passed. #4 failed on 3 of 4 on insite injector test and it won’t stop so replacing #4 “fingers crossed”!! RE: Peterbilt 2015 cm2350 list of issues - tree98 - 01-23-2025 Did you first try retorquing the feed tube? And also if you do replace that injector you MUST replace the feed tube as well. They are a crush fit and become a matched set after tightening. |
