| Front crank seal - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Front crank seal (/showthread.php?tid=1468) Pages: 1 2 |
Front crank seal - joed2323 - 02-13-2017 I have a cm2250, what specialty tools would I need to replace this seal? Also what parts would I also need besides the seal? I've done them on series 60s and I thought they were a fairly easy to do. RE: Front crank seal - snailexpress - 02-13-2017 (02-13-2017 )joed2323 Wrote: I have a cm2250, what specialty tools would I need to replace this seal? Also what parts would I also need besides the seal?cummins quickserve best place to find answers. It's free just register engine serial # RE: Front crank seal - Brock - 02-13-2017 My mechanic says they are very easy to screw up which is why he always has a spare. RE: Front crank seal - Hammerhead - 02-13-2017 (02-13-2017 )joed2323 Wrote: I have a cm2250, what specialty tools would I need to replace this seal? Also what parts would I also need besides the seal? You need tool part #3162992 Front Crank Seal Remover/Installer to do this procedure with the best chance of success. The procedure is in Quickserve->ISX Service Manual->Section 1 Cylinder Block->10-001-023 Crankshaft Seal, Front RE: Front crank seal - SquareOne - 12-07-2024 Thought I'd revive this old thread as this is something I'll be doing before the end of the year. Another result of this cold snap has appeared to enhance this front crankshaft seal seep. Been having some build up around the area for awhile, but now has just touched the front right corner of the oil pan. Guess it's to be expected at almost 900k. Not a huge deal by any means, but I do not like leaks and will address any 'enhanced' seep before it actually becomes a leak. - Would the part number (4918991) which Cummins recommends for the seal replacement/installation be a good part to use, or is there a better option available? I've seen the tool range from $250-450 depending on site and manufacturer. - Also, front crank seal number 3685173 looks to be the correct part on QuickServe for anyone hunting for it. RE: Front crank seal - Yauchout - 12-07-2024 as far as the tool goes i used this one off of amazon for $69 without a problem i dont really see the need to spend the 250-450 https://amzn.to/4f7F43L RE: Front crank seal - Mrkentee - 12-08-2024 (12-07-2024 )SquareOne Wrote: Thought I'd revive this old thread as this is something I'll be doing before the end of the year. Another result of this cold snap has appeared to enhance this front crankshaft seal seep. Been having some build up around the area for awhile, but now has just touched the front right corner of the oil pan. Guess it's to be expected at almost 900k. Not a huge deal by any means, but I do not like leaks and will address any 'enhanced' seep before it actually becomes a leak. On my truck, the radiator has to come out to get the tool in there. Makes it into a big deal. ☹️ RE: Front crank seal - SquareOne - 12-08-2024 (12-07-2024 )Yauchout Wrote: as far as the tool goes i used this one off of amazon for $69 without a problem i dont really see the need to spend the 250-450 Damn, thats a good find if it works like it needs to! I'll (hopefully) only need to use it once or twice for quite sometime. As long as it does the job correct, that's all I'm concerned with. (12-08-2024 )Mrkentee Wrote: On my truck, the radiator has to come out to get the tool in there. Makes it into a big deal. ☹️ I'm wondering the same. It's a Cascadia, so not sure how it's going to be. The balancer replacement wasn't an issue a little while back, but have yet to do the seal. RE: Front crank seal - Heavyhauler - 12-08-2024 I have a 2009 short nose Pete , I had enough room to for the Puller tool. I used some cheap one I had laying around. Tho I spent the time to make sure I had room , I pulled the fan and the shroud itself. Be gentle with the new seal, they are only backed by thin tin and bend easy. As does your small front cover that they bolt to so (don’t) pry to hard. Because it will leak….. ask me how I know |
