| Aussie @m*m^2 Tuned ISX - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: The Bragging Channel... (/forumdisplay.php?fid=78) +--- Thread: Aussie @m*m^2 Tuned ISX (/showthread.php?tid=2586) Pages: 1 2 |
Aussie @m*m^2 Tuned ISX - adam isx - 01-11-2018 Hi All from Australia Well today was the day I was waiting for I recently had my 871 ISX Tuned (@m*m^2) and dialled in at a safe level of boost@ 36 psi I also own a Cat Powered C15 Acert with a Pitts power box and Manifold, (on level 2) (Factory file is 625hp)=680hp @ 56 psi boost (twins) Both trucks loaded to 46 tonnes gross weight on a bridge (101k lbs) Both trucks with same gearbox's and final drive ratios (4.33) Well the proof is in the @m*m^2 tune The ISX was 600hp @ 2050 from factory and could even come close to the Cat powered truck before the tune, No Contest at all!! Well today was eye opening, the Isx pulled away down low about half a gear on the Cat Then we hit a big hill!!, and they both where locked in a battle as neither truck could out pull each other!! door to door up the side of a mountain. This is simply amazing!!, As the Cat powered truck with the power box turned on setting 2 is usually untouchable as its a beast also @ 680hp Pleasantly surprised with the tune I am from Australia and there is not a lot Help here, only Stealerships that take your hard earned. Only through this Site I was able to Achieve this Big thanks goes to Signature 620 for the outcome achieved Cheers Adam RE: Aussie @m*m^2 Tuned ISX - Rawze - 01-11-2018 Makes you wonder what Piss power is calling 680 hp eh? RE: Aussie @m*m^2 Tuned ISX - hhow55 - 01-11-2018 Nothing like a beast in the land down under! Lol RE: Aussie @m*m^2 Tuned ISX - smorgan87 - 01-11-2018 Id be curious to see that cat on a dyno. See what shes really doing. RE: Aussie @m*m^2 Tuned ISX - Rig Wrench - 01-11-2018 Pitts box works, kinda antique technology. Boost is kinda low on that kitty for a 625, especially with a box. I'd expect 60ish + on a true 625 Acert. The right big CPL 870-871 is no joke. Get ahold of Gearhead if you want that cat to hang with that cummins RE: Aussie @m*m^2 Tuned ISX - Signature620 - 01-12-2018 They're a good honest engine once you let them breathe a bit of fresh air. RE: Aussie @m*m^2 Tuned ISX - Running rough - 01-12-2018 (01-11-2018 )Rig Wrench Wrote: Pitts box works, kinda antique technology. Boost is kinda low on that kitty for a 625, especially with a box. I'd expect 60ish + on a true 625 Acert. The right big CPL 870-871 is no joke. Tell you buddy to get ahold of Gearhead if he wants that cat to hang with that cummins I can’t see how the Acert cat can hold a head gasket with that amount of boost, I threw my cat out in one of my trucks because to many headgaskets failures and it was recently overhauled and In the proses of putting in a 2250 with low km I got from a wrecker ,(put a new fuel pump on it) yes there are some who will think I took a big step backwards, worst case scenario it will drop a liner, if that happens I know it can be cut and shimmer and theoretically should be good for a long long time if done right, but am keeping fingers crossed that this one will not have that issue, I have big demons to slay getting the wiring to work I know that RE: Aussie @m*m^2 Tuned ISX - Rig Wrench - 01-12-2018 (01-12-2018 )Running rough Wrote:(01-11-2018 )Rig Wrench Wrote: Pitts box works, kinda antique technology. Boost is kinda low on that kitty for a 625, especially with a box. I'd expect 60ish + on a true 625 Acert. The right big CPL 870-871 is no joke. Tell you buddy to get ahold of Gearhead if he wants that cat to hang with that cummins That high boost doesn't all go into the cylinders. The Iva's bleed of cylinder pressure. That's why when you look into an Acert head its all soot like an egr engine is RE: Aussie @m*m^2 Tuned ISX - Rawze - 01-13-2018 (01-12-2018 )Rig Wrench Wrote:(01-12-2018 )Running rough Wrote:(01-11-2018 )Rig Wrench Wrote: Pitts box works, kinda antique technology. Boost is kinda low on that kitty for a 625, especially with a box. I'd expect 60ish + on a true 625 Acert. The right big CPL 870-871 is no joke. Tell you buddy to get ahold of Gearhead if he wants that cat to hang with that cummins They also have a lower compression ratio, different piston & skirts, perhaps different stroke?, different injection style (mostly CDI), different valve over-lap, thicker components and a lot of other things that are not the same as other model engines. They are more forgiving of abuse and bad programming due to these factors and a lot of guys over-boost them and do all sorts of bad things through sheer ignorance on them and get away with it. |
