Boost gauge on DD15 - Printable Version
+--- Forum: Freightliner related help (/forumdisplay.php?fid=75)
+--- Thread: Boost gauge on DD15 (/showthread.php?tid=2792)
Pages: 1 2 3
RE: Boost gauge on DD15 - Rawze - 01-09-2023
(01-09-2023 )Seanp1226 Wrote:  ..
Ok. Thank you for that. My truck is a 2019 and I do not have a plug. I will have to drill a hole and tap the hole to install a boost gauge.
be sure to remove the component from the engine before drilling, etc. so that shavings or metal dust do not end up in the intake valves or cylinders.
