| EGR tuneup - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: EGR tuneup (/showthread.php?tid=3337) |
EGR tuneup - Jorg81 - 07-22-2018 So I’ve watched the EGR tuneup video. Just have a quick question. It didn’t show you cleaning the pipes and such. Do you use the carb/choke cleaner and like a wire brush or something to clean them? RE: EGR tuneup - hhow55 - 07-22-2018 Yes, you need to clean the piping. I used Palmolive dishwashing liquid, the green colored. I picked up a toilet bowl brush, and it all came clean. RE: EGR tuneup - Jorg81 - 07-22-2018 (07-22-2018 )hhow55 Wrote: Yes, you need to clean the piping. I used Palmolive dishwashing liquid, the green colored. I picked up a toilet bowl brush, and it all came clean. Ok I wasn’t sure if I should use any cleaner. I was just reading Rawze’s article about it and he said using cleaner can cause it to collect soot even faster afterwards. Maybe it depends on what you use. |
