Help with pulling the programming from the ecm - Printable Version
+--- Thread: Help with pulling the programming from the ecm (/showthread.php?tid=3375)
Pages: 1 2
RE: Help with pulling the programming from the ecm - snailexpress - 08-04-2018
The soft name ie misspelled to keep google out.
The adapter you need is on the same page down. Inline 6 or Inline 7.
Many of us bought it from china.
RE: Help with pulling the programming from the ecm - Evotrucker - 08-04-2018
(08-04-2018 )snailexpress Wrote:
(08-04-2018 )Evotrucker Wrote:  So I made it back to the shop to pull the programming from the ecm.... I'm on insite trying to find how and can't. I figured it would be intuitive. Uni told me to pull a file called C@ltr!m? Can someone tell me how or where this s.o.b is at.
Thanks ahead of time.
C@ltr!m is program to work with calibration file.
If you don't have C@ltr!m you can't. Uni can establish remote connection with yours ECM if you have Inline adapter.
Don't think Cummins shop will participate.
RE: Help with pulling the programming from the ecm - rrod - 08-05-2018
(08-04-2018 )Unilevers Wrote:  ya ill sort you out, i figured just asking for a file was too good to be true!
ahahahaha!!!!! i was happy too, i figured it would be easy peazy. but noooooo..... its not lol. i thought it would be a feature in insite.
Same here. I started looking at it and said, nop, nop, I’m not touching that. Not sure how to figure it out.
