Dpf can repair - Printable Version
+--- Thread: Dpf can repair (/showthread.php?tid=4276)
Pages: 1 2
RE: Dpf can repair - DVT873 - 03-16-2019
Been doing it for a long time, cold water or sometimes wax. Depending on location the MiniDuctor provides flameless heat but is pricey. Also have a jewelers torch. Looks funny as hell but puts out a pinpoint flame up to 5000 degrees. Handle is the size of a majic marker. Good for side cutting turbo mounting nuts where access is tight.
RE: Dpf can repair - DSTdriver - 03-17-2019
Most likely its stainless steel
McMAster-Carr has stainless fittings
Maybe grind it down some & weld a new fitting over it
Let us know the outcome
