Truck shut off - Printable Version
+--- Thread: Truck shut off (/showthread.php?tid=4814)
Pages: 1 2
RE: Truck shut off - hhow55 - 07-18-2019
I had the same issue once, turned out to be loose connection on power distribution block.
RE: Truck shut off - Lonestar10 - 07-18-2019
when i was trying to install a reman ecu from cummins last week the low coolant red stop engine light and all other buzzers went off before the truck wouldnt even restart again.
turned out was a bad power on pin as they couldnt get their system to connect and i couldnt get mine. i had been watching in CT before it shutdown for good as the battery voltage was fluctuating up and down even though volt meter was sitting steady at 14 volts.
