No run ISX - Printable Version
+--- Thread: No run ISX (/showthread.php?tid=488)
Pages: 1 2
RE: No run ISX - bgblk1968 - 06-06-2016
Yes I double checked fuel solenoid and it was good. Put 6 reman injectors in it and ran like a top. I presume the high speed runaway did internal damage to nozzles. Thanks everyone fir the tips and suggestions!!
RE: No run ISX - Rawze - 06-06-2016
(06-06-2016 )bgblk1968 Wrote:  Yes I double checked fuel solenoid and it was good. Put 6 reman injectors in it and ran like a top. I presume the high speed runaway did internal damage to nozzles. Thanks everyone fir the tips and suggestions!!
Sounds like it may have been pushing a lot of air back through the fuel rail, keeping it from running.
An injector leak-down test would have likely revealed that one. I will keep that in mind next time someone calls me up and says they tried everything else.
