Pressure testing CM870 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Pressure testing CM870 (/showthread.php?tid=5256) |
RE: Pressure testing CM870 - Chamberpains - 11-04-2019 You got it DDlight. Just make sure your rigging into the 6" intake is right at the turbo. That big rubber intake hose will not hold pressure. You'll probably blow that apart if you try. |
