ISX450.......unrealistic expectations? - Printable Version
+--- Thread: ISX450.......unrealistic expectations? (/showthread.php?tid=5271)
Pages: 1 2 3
RE: ISX450.......unrealistic expectations? - Lonestar10 - 11-09-2019
basically the same just pipes run different directions the EGR pipe runs over top of engine instead of behind the engine like the cm871.
RE: ISX450.......unrealistic expectations? - hhow55 - 11-09-2019
(11-08-2019 )Mattman Wrote:
(11-08-2019 )hhow55 Wrote:  My, My such a small world. I use to pull a lot of hcl, and caustic out of that plant when it was basf.
What plant are you referring to? The one in my picture is in South Arkansas. The only product this plant produces is Bromine. They do use caustic for the scrubber. Use HCL but not really sure why, more as a cleaner agent I believe.
Baytown, tx
RE: ISX450.......unrealistic expectations? - tree98 - 11-09-2019
(11-09-2019 )Golfnut Wrote:  Today I pulled out the Delta-P sensor and the IMAP sensor. Both are covered and plugged with soot so it looks like I'll be learning how to do an EGR Tuneup. I see most of Rawze's videos are for an 871. Are there any good resources for a CM2350?
yes the principal is the same
RE: ISX450.......unrealistic expectations? - JMBT - 11-09-2019
You can find all the sensor locations for your motor on QuickServe. Just register your engine number and it will be specific to your 2350. There should be diagrams showing the sides and top that will point out all the sensors and such.
