CM2350 Fuel Pump Rebuild Help - Printable Version
+--- Thread: CM2350 Fuel Pump Rebuild Help (/showthread.php?tid=5315)
Pages: 1 2
RE: CM2350 Fuel Pump Rebuild Help - Waterloo - 11-13-2019
(11-13-2019 )Golfnut Wrote:  I just got it put back together and started it up. I was real nervous about starting it up! But it runs like its supposed to and I don't see any leaks.
Welcome to EPA trucking... Ping's here, Volkey wedges and an Oddesey putter...
I would rather be golfing... :-)
RE: CM2350 Fuel Pump Rebuild Help - tree98 - 11-13-2019
(11-13-2019 )Waterloo Wrote:  [quote='Golfnut' pid='46272' dateline='1573686612']
What??
RE: CM2350 Fuel Pump Rebuild Help - Golfnut - 11-13-2019
Mizuno irons and wedges, Scotty Cameron putter, old Titleist Driver......don't play enough anymore.
RE: CM2350 Fuel Pump Rebuild Help - DSTdriver - 11-13-2019
(11-13-2019 )Golfnut Wrote:  Mizuno irons and wedges, Scotty Cameron putter, old Titleist Driver......don't play enough anymore.
How many miles & hrs on your eng ?
How often you change eng oil ?
How did the old parts look ?
RE: CM2350 Fuel Pump Rebuild Help - Golfnut - 11-14-2019
The truck as 326,000 miles and about 10,000 hours but it is new to me and I wasn't able to get the service history. The old parts from the pump looked line new still so that was very encouraging. I've only put about 1200 miles on it and most likely will only put about 10,000/year. But those miles will be hard grain hauling miles on gravel roads with frequent stops and starts and idling.
RE: CM2350 Fuel Pump Rebuild Help - DSTdriver - 11-15-2019
Thanks for the info as I'm right there on mileage & eng hrs on mine
So as soon as we get a break in the work load I'm gonna do mine also
Good job on the rebuild & the post & the others that came on for the extra tips
