Screaming Truck - Printable Version
+--- Thread: Screaming Truck (/showthread.php?tid=5626)
Pages: 1 2
RE: Screaming Truck - 74bassman - 12-28-2019
it was the broken bolt and gasket on the intake that was leaking.
RE: Screaming Truck - Mattman - 12-28-2019
I like easy fixes.
Now since you are good at finding a leak:. When I turn exhaust brake on, doesn't matter which setting, I hear a noise believe it to be an exhaust leak. Haven't seen a trace of soot around turbo or exhaust manifold. I may be looking on the wrong side. I don't hear a noise while it is under a load and boosting about 30psi.
RE: Screaming Truck - Rawze - 12-29-2019
(12-28-2019 )74bassman Wrote:  it was the broken bolt and gasket on the intake that was leaking.
That's a new one... thanks for sharing.
RE: Screaming Truck - 74bassman - 01-04-2020
how do I attach a audio file? I did record what it sounded like. Just did a 3 day run, and all is good.
