Fuel/water separator filter turning black - Printable Version
+--- Thread: Fuel/water separator filter turning black (/showthread.php?tid=6571)
Pages: 1 2 3 4
RE: Fuel/water separator filter turning black - Pd6cas2 - 09-07-2020
It’s a very simple setup with a vacuum sensor” plug & play , I will take pics of it tomorrow!
the challenging part is finding a port on the IFSM!
RE: Fuel/water separator filter turning black - smorgan87 - 09-07-2020
My filters usualy black in just a cpl days. Id be worried if it wasnt cause it aint doin its job. Watch the fuel level in the bowl, should gradually rise to the top between oil changes.
RE: Fuel/water separator filter turning black - JimT - 09-07-2020
So, it seems i'm a little late to the party here.
Before I present an unsolicited product endorsement for my preferred diesel biocide I should point out there are basically 3 reasons you could be clogging up your fuel filters:
Microbial growth, often referred to as "algae", it's actually bacteria or fungi growing in the water of your fuel tank and feeding on the hydrocarbons. This appears to be a bigger concern with biodiesel and blends.
Asphaltenes, a hyrdocarbon often formed when heated fuel is returned to the storage tank. Very common in modern common rail fuel systems. While they supposedly don't hurt the engine, it can clog up filters and, in high concentrations, can actually create thick sludge (like a varnish).
Debris, either from external contamination or often from the breakdown of older rubber fuel lines (more common on 10+ year old equipment, especially if it sat for an extended period of time).
How do you know which one you are dealing with?
Quote:Although both asphaltenes and bioorganisms will look black and shiny, the nose knows. “If you smell the filter when you change it and it smells like diesel fuel, it’s asphaltenes,” he says. “If it smells horrible, it’s microorganisms.” [1]
I haven't spent much time (yet) researching asphaltene treatments and I have no personal experience using them.
As for biocides, my research points to 2 products, BioborJF and Star Brite Bio Diesel. Each is highly effective against different types of microbial life. [3]
Anyway, with the occasional use of a biocide my davco filter no longer turns black. I had a problem not long after getting the truck where the davco would get black almost instantly. Gave her a couple shock treatments of Biobor JF and that cleared things right up. Now every month or 3 I'll add a maintenance dose of Biobor JF and it will keep the filter looking pretty clean for 10-15k miles. It darkens a little, but no where near "black".
There's a bunch of different biocides on the market and based on some articles I read there's really 2 different things that they kill. Most work better with one or the other. I chose Biobor JF due to it's overall effectiveness and it boosts the lubricity of the fuel too. However it should be known that it's technically not approved for on-highway use but farm equipment, aviation, boats, gensets are all ok. Best I can figure from web research it's some EPA pesticide thing. Since I don't follow the EPA guidelines with my truck emissions I figure it won't hurt to disregard this too ;)
Resources:
[1] https://www.truckinginfo.com/156177/keeping-diesel-fuel-clean
[2] https://www.pbo.co.uk/gear/12-diesel-bug-treatments-tested-43353
[3] https://www.practical-sailor.com/boat-maintenance/diesel-biocides-take-on-contaminated-boat-fuel
[4] https://www.practical-sailor.com/wp-content/uploads/2020/02/0709-BIOCIDES-BACTERIA.pdf
Anyway, if anyone has more "lite" reading, please share!
RE: Fuel/water separator filter turning black - 74bassman - 09-24-2020
I'm was doing an oil change today, and decided to take a better look at this. My davco turns black about 5k to 7k miles, change it no big deal. After following the other thread about serving this fiter, I got to wiping the spring in the housing. I noticed this black stuff wipe right off. I didn't notice before because it was all the same color. I also notice in the bowl area same thing. This is black wipes right off, and is slimy.
RE: Fuel/water separator filter turning black - Lonestar10 - 09-24-2020
Slimey algae, gritty asphaltine is what I've typically used as a reference
RE: Fuel/water separator filter turning black - Chamberpains - 09-24-2020
Or just dirty diesel... it comes from crude oil and is dark green and yellow in color till its circulated a few times through the filters. Then its nice and see through light yellow.
