Looking for a code scanner - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Looking for a code scanner (/showthread.php?tid=6576) Pages: 1 2 |
RE: Looking for a code scanner - wespipes - 09-06-2020 I use the Bosch hds 250 https://amzn.to/39Ygrrs RE: Looking for a code scanner - tree98 - 09-06-2020 (09-06-2020 )JAsaro Wrote:(09-06-2020 )tree98 Wrote:(09-06-2020 )JAsaro Wrote: I was looking at the Cando hdcode2 It comes with the software on a disc. You'll have to install it on a computer. RE: Looking for a code scanner - JAsaro - 09-06-2020 (09-06-2020 )tree98 Wrote:(09-06-2020 )JAsaro Wrote:(09-06-2020 )tree98 Wrote:(09-06-2020 )JAsaro Wrote: I was looking at the Cando hdcode2 Thank you RE: Looking for a code scanner - Rawze - 09-06-2020 (09-06-2020 )JAsaro Wrote: I was looking at the Cando hdcode2 complete waste of money, as you can get insite for the same price .. and be able to actually troubleshoot the truck and re-calibrate the turbo, do injector tests and all the stuff, same as OEM but that scanner cannot do. RE: Looking for a code scanner - alborz - 09-06-2020 I've been trying to find the insite for last couple weeks in the internet but no luck. The Inline I bought came with a CD for inline. [/u] RE: Looking for a code scanner - Chamberpains - 09-06-2020 ebay and alibaba have plenty of insite and inline adapters posted. I think there are entire sites dedicated to selling diagnostic software. Plus there are the auto forums that cost a nominal fee to join. They usually have it posted free. Then there are the torrent sites... file sharing sites.... file sharing communities... its everywhere no matter how far down the rabbit hole you go. You're not looking very hard RE: Looking for a code scanner - MageRoyal - 09-06-2020 pm sent. RE: Looking for a code scanner - Rhase trans - 09-14-2020 Will this work for a 2019 x15 or do I need something more updated? I just purchased two 19's with cm2350's in them. My first cummins I've always had cats before. RE: Looking for a code scanner - tree98 - 09-14-2020 You need insite 8 or higher for X15. |
