|     Looking for a code scanner    |
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #1   |  |||
|  Looking for a code scanner    Looking for a good code scanner I’m a o/o just want to check codes and clear them and do a Regen is need be thanks     |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #2   |  |||
|  RE: Looking for a code scanner    This is the one most of us use here... I do, works fine, had it for around five years. Insite software comes with it. https://www.ebay.com/itm/Cummins-INLINE-...SwIJlZ9U~7   User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields.  |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #3   |  |||
|  RE: Looking for a code scanner    So I would just need a pc and download the file and if would read/clear codes ? I’m new to this stuff     |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #4   |  |||
|  RE: Looking for a code scanner    I was looking at the Cando hdcode2     |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #5   |  |||
| RE: Looking for a code scanner | |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #6   |  |||
|  RE: Looking for a code scanner    I use this to just read the codes, it won’t clear them but if ya fix the underlying issue the fault code will go inactive or clear itself anyway.   User's Signature: That’s pronounced, /ˈs(k)izəm/  |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #7   |  |||
 RE: Looking for a code scanner  (09-06-2020 )JAsaro Wrote: I was looking at the Cando hdcode2 Just get an old laptop wipe it clean and install insite. Then don't use it for anything but working on your engine, don't surf the interweb and hang out on pornhub with it. If you have a cummins you NEED insite!! Not ANYTHING else. Just buy the inline adapter that waterloo linked for you and call it a day. It does all diagnostic tests, read/clear codes,forced regen's, dpf resets, computer reflashing, etc. Anything else you buy won't be as good and will probably cost a LOT more.  |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #8   |  |||
 RE: Looking for a code scanner  (09-06-2020 )tree98 Wrote:(09-06-2020 )JAsaro Wrote: I was looking at the Cando hdcode2 Ok thanks I will do that  |  |||
|    09-06-2020, (Subject: Looking for a code scanner )   Post: #9   |  |||
 RE: Looking for a code scanner  (09-06-2020 )tree98 Wrote:(09-06-2020 )JAsaro Wrote: I was looking at the Cando hdcode2 Sorry does it come with the insite installed or do I have to buy and download it myself  |  |||
