Cam bearings - Printable Version
+--- Thread: Cam bearings (/showthread.php?tid=688)
Pages: 1 2 3
RE: Cam bearings - Wiseman - 07-28-2016
(07-28-2016 )jimeneztrans84 Wrote:  Is there a way or anyone done a oil bypass filter for cm2250?
With correct remote touch on the ECM , there's no need for oil bypass filter , because oil stays almost sparkling clean .
RE: Cam bearings - yamajason - 07-28-2016
That remote computer stuff sure is convenient, but the extra time to go meet the guy that will tune it and drive it then re-tune it to get that little extra fuel $ that adds up for the next years....as well as the guy that replaces the dealer when I have problems in the future. Worth the trip to me.
You're absolutely right!!!!
RE: Cam bearings - jimeneztrans84 - 07-28-2016
Is the bypass hookup for cm2250 and 871 just about the same?
RE: Cam bearings - overshot - 07-28-2016
(07-28-2016 )jimeneztrans84 Wrote:  Is the bypass hookup for cm2250 and 871 just about the same?
Yes it is
http://rawze.com/forums/showthread.php?tid=431
Where did you get that fitting that screws on the side of the block? Size?
RE: Cam bearings - overshot - 07-30-2016
(07-28-2016 )jimeneztrans84 Wrote:  Where did you get that fitting that screws on the side of the block? Size?
The size for the fitting in the oil cooler is M14 to #8 jic
Return line into the block is M18 to #8 jic. You can get them at some hydraulic stores. I prefer steel fitting.
Be sure not to over torque them.
Tags:
bypass oil fittings,bypass,oil bypass,oil plugs
