Transmission jacks....any suggestions? - Printable Version
+--- Thread: Transmission jacks....any suggestions? (/showthread.php?tid=7051)
Pages: 1 2
RE: Transmission jacks....any suggestions? - smorgan87 - 02-19-2021
I get by ok with the heavier harbor freight trans jack but as stated b4 the casters suck and the plate adjustments arent the greatest either. If i used one more than once ever cpl years id certainly spring for a cpl hunnit more bucks on a good one.
RE: Transmission jacks....any suggestions? - Kingman11 - 02-19-2021
I used the Harbor Freight lift table to drop mine and it was a breeze. I didn’t install the table handle and it slides under there and the wheels don’t lock up as easy as the jack.
https://www.harborfreight.com/1000-lbs-capacity-hydraulic-table-cart-60438.html
RE: Transmission jacks....any suggestions? - JMBT - 02-21-2021
That’s an interesting idea Kingman11 that I had not considered.
Ahub86: thanks for the pics!!
I bought the harbor freight 2000lb jack it was on sale for $249, normally $329, so I couldn’t pass it up. I think the OTC road ranger plate could be bolted on nicely based on the pics from Ahub86, so I may order on of those in as well.
Thanks again for all the feedback!
