New model Mack diagnostic software - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: New model Mack diagnostic software (/showthread.php?tid=7163) Pages: 1 2 |
RE: New model Mack diagnostic software - Waterloo - 03-19-2021 For a legit NexIQ, try FleetPride or Grainger, they sell the real units. I recall Rawze bought one on Amazon, it was listed as the real deal, it was a Chinese knock off and did not work, he bought his current one from a local distributor. RE: New model Mack diagnostic software - a113n - 03-20-2021 I got my nexiq adapter from diesel laptops. I believe price was $650 plus shipping and that was about a year ago. It is genuine nexiq, not a knock off RE: New model Mack diagnostic software - Coronado126 - 03-20-2021 (03-19-2021 )Mattman Wrote: Coronado 126. You seem to know what you are talking about. I am all for saving a few bucks, but sometimes that can cost you more in the long run. I ran the $600 version for a couple years and it did everything except ECM calibrations so I would recommend that one if your only trying to do basic things. On the adapter, yeah the Nexiq 2 is the best around, but you may be able to find a VOCOM or VOCOM 2 for pretty cheap on ebay. The VOCOM is the actual Volvo comm adapter like the Inline is for Cummins. There are chinese ones out there that I've read mixed reviews on. A used legit VOCOM would be the way to go IMO. Also, PTT does allow the use of pretty much all the adapters on the market, so it may be worth a shot to just get the software and try your Cummins adapter after setting up your connection preferences. RE: New model Mack diagnostic software - victory26 - 03-22-2021 (03-20-2021 )Coronado126 Wrote:(03-19-2021 )Mattman Wrote: Coronado 126. You seem to know what you are talking about. I am all for saving a few bucks, but sometimes that can cost you more in the long run. PTT works with an inline adapter but is very slow. He needs nexiq or vocom. RE: New model Mack diagnostic software - cybernetictrout - 08-09-2022 (03-19-2021 )Coronado126 Wrote: Best price on the Nexiq 2 is Amazon, just make sure you check and are buying a legitimate one and not a Chinese knock off. my problem is buying 1000 dollars worth of software just to use it only 3 or 4 times in the year. i dont like charging people hundreds of dollars for programming fees as of when you do owner operators lot at you like your ripping them off |
