Need help & educated on tunes. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Need help & educated on tunes. (/showthread.php?tid=7658) Pages: 1 2 |
RE: Need help & educated on tunes. - Rawze - 08-24-2021 (08-24-2021 )PuroCumminsPower Wrote: ... just register your engine ser# on quickserv.com ... its free .. and all the part#'s and drawings are there. RE: Need help & educated on tunes. - Mr Hagg - 08-25-2021 2864399 is for the jake wiring harness. A 871 dont have injector harness. We only replace the harness when we see oil seeping out side engine. Engine brakes solenoids go bad a good bit. that can be a issue. We also see rocker shafts with a lot of ware and it causes oil pressure to be weak on jakes.. We replace a lot of jake rockers as well... RE: Need help & educated on tunes. - PuroCumminsPower - 08-25-2021 Thanks gentlemen. Much appreciated. RE: Need help & educated on tunes. - Dynogt17 - 09-11-2021 Update. Passed injector leak down, no oil in the injector harness that i can see. Makes no sense. I start it i have a valve like chatter when its extremely hot 90degs outside and runs decent around 80degs. Sounds really dumb i know. I wish i could get it down to you Mr. Hagg. At this point Im done just gonna drive it. Itll show its issue or Ill buy something more my speed like a n14 or series 60. |
