cm871 VGT nozzle rebulid kit to trust or not to trust? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: cm871 VGT nozzle rebulid kit to trust or not to trust? (/showthread.php?tid=767) |
RE: cm871 VGT nozzle rebulid kit to trust or not to trust? - Hammerhead - 08-21-2016 I believe the 870 returns the coolant into the block via ports on the block side via where the frost plugs get installed in the block of the 871... RE: cm871 VGT nozzle rebulid kit to trust or not to trust? - Unilevers - 08-22-2016 i don t agree with removing the cooler on a 870 BUT - its not as bad as the the 871's and up. The coolant doesn't flow the same and it does not hurt them as much. I do not recommend disrupting the coolant flow in a block, but if it is already done i wouldn't stress out too much about it as its not as major on the older ones. It comes in near the top of the thermostat housing and then returns through 2 ports in the side of the block in front of the turbo. |
