High oil temp and pressure sluggish moyor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: High oil temp and pressure sluggish moyor (/showthread.php?tid=7806) Pages: 1 2 |
RE: High oil temp and pressure sluggish moyor - hookliftpete - 10-26-2021 Liquids will ruin them and wash the metals that aid in the combustion of the soot. I played the wash out game for about 6 months on my own truck because I wanted to demandate and the engine was not practical to keep mandated. (Some blowby, uses some oil, idles/stop and go traffic). They will need to replace them on your truck or you will need to demandate, etc. RE: High oil temp and pressure sluggish moyor - Rawze - 10-26-2021 (10-26-2021 )Crosscarriers Wrote:(10-26-2021 )hookliftpete Wrote: If they washed the dpf and catalyst, theyre ruined....... Ive seen videos of ppl power washing them YEAH< and I have seen people make videos on putting super-glu in their hair too.. DOES NOT MEAN IT IS OK TO DO!!!! YOU CANNOT USE ANY LIQUIDS ON THEM... IT SEVERELY WEAKENS THEM EVERY TIME YOU DO!!! AND IT WASHES OUT THE PRECIOUS METALS IN THEM... NO LIQUID CURES FOR THEM!!!... REF: http://rawze.com/forums/showthread.php?tid=5941&pid=51493#pid51493 and... http://rawze.com/forums/showthread.php?tid=7390&pid=65208#pid65208 and more if you search around. =========== there is only one way to clean them properly.. here is a fine example... http://rawze.com/forums/showthread.php?tid=5884&pid=50975#pid50975 RE: High oil temp and pressure sluggish moyor - GhostHauling - 10-27-2021 That entire situation sounds a bit odd to me…. Just thinking out loud. |
