| HP gain - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: HP gain (/showthread.php?tid=8294) |
HP gain - o96r - 06-26-2022 Hello everyone, I’m trying to “turn up” my ISX and I was told This is the place to ask. Shops around me won’t touch it because of emissions. I’m not trying to mess with emissions just looking for a little more power. Finally they Dealer said they could to it but after further research Cummins told them there is no available update/tune for my engine “because it was a very specific built engine.” Guy at the dealer said he’s never seen or heard of something like this. They were willing to do the tune of Cummins would provide it. I was wondering if anyone else has had this issue? Sorry for the ignorance I come from older cats and detroits. Info given to me from dealer…. 2004 signature series Cm870 Serial # 79052701 450hp 1550 tq Thanks, RE: HP gain - Rawze - 06-26-2022 (06-26-2022 )o96r Wrote: Hello everyone, It is a run of the mill CPL 8520 engine. Noting special about it other than the cams need to be set a 6/6 offset rather than 4/6 during an inframe. It is quite common of an engine and is not 'special'. Yours is also a a typical 2-engine brake solenoid engine, so it needs a compitable program as such. As far as standard programs from cummins goes that any stealers$it can flash into it, a compare of the more than 6,800+ settings in the program reveals that ... * Program AB10525 (500HP, 1650Trq) is 100% compitable with your ser# engine. * Program AB10487 (450HP, 1750Trq) is also 100% compatible with your ser# engine. RE: HP gain - o96r - 06-26-2022 (06-26-2022 )Rawze Wrote: It is a run of the mill CPL 8520 engine. Noting special about it other than the cams need to be set a 6/6 offset rather than 4/6 during an inframe. It is quite common of an engine and is not 'special'. Thanks! Now to try and find someone who can do it near Chicago. I didn’t think what they said was true. And it’s not like I’m trying to tune to 700 hp. Just want to wake her up a little RE: HP gain - Rawze - 06-27-2022 (06-26-2022 )o96r Wrote: ... Just about any stealers$it can flash one of those programs that I mentioned into it. RE: HP gain - o96r - 11-10-2022 Im still having issues finding someone to do it… what kind of computer or software does one need to do it themselves…. I’d that even possible? RE: HP gain - Rawze - 11-10-2022 (11-10-2022 )o96r Wrote: Im still having issues finding someone to do it… what kind of computer or software does one need to do it themselves…. I’d that even possible? Any OEM stealers$it should be able to put Program AB10525 into it. If you are looking for your own version of the Insite + adapter.. just google "cummins inline-6 kit" and you will find plenty of websites that sell them for about $300 or so. RE: HP gain - windowrattler - 11-10-2022 I'm about 4 hours north of you. I've been to Chicago twice since your original post. Should be there sometime over Xmas also. It would be pretty straight forward to flash the stock cal that rawze pointed out. Feel free to pm me. RE: HP gain - Aleeex - 11-11-2022 If you’re ever near Spartanburg sc I can do it RE: HP gain - o96r - 11-13-2022 Thanks guys! |
