Coolant leak in holding tank....Line X to the rescue - Printable Version
+--- Thread: Coolant leak in holding tank....Line X to the rescue (/showthread.php?tid=928)
Pages: 1 2
RE: Coolant leak in holding tank....Line X to the rescue - T680 - 09-25-2016
I had line x-Ed my pickup bed....never thought about coolant tank
Did used POR 15 to paint the old Volvo frame after I cleaned of rust...indeed is very tough paint too...u can chose colors too
RE: Coolant leak in holding tank....Line X to the rescue - preacherboy24 - 09-29-2016
Well.....I ran it this week and no issues. It worked.
RE: Coolant leak in holding tank....Line X to the rescue - preacherboy24 - 10-15-2016
Tank update.....fail
It began to leak right at where the tank originally began to leak.
I would have never figured it would do that but ....it did.
Well.....its $180 no one else will have to spend on trying it out.
I purchased a new tank at Napa and I really like it. You can see the coolant in the tank so if oil or fuel starts to seep into the coolant I will catch it right away.
RE: Coolant leak in holding tank....Line X to the rescue - Hammerhead - 10-15-2016
Sometimes you never know until you try.
Thanks for trying, and for sharing.
RE: Coolant leak in holding tank....Line X to the rescue - Rawze - 10-16-2016
(10-15-2016 )preacherboy24 Wrote:  Tank update.....fail
Here is the correct solution to coolant tank repair,.. - I have done this successfully more than a few times.
http://rawze.com/forums/showthread.php?tid=1019&pid=8648#pid8648
